Question about Quinny ZAPP Stroller
My quinny buzz handlebar frame has broken away from the black lock button connection point this is on one side only.
    Problem Solver:
  • 18 Answers
Hi to everybody I repair the cables and replace foam grips / bumper foam on these models
Posted on Jun 11, 2011
    Champion:
  • Quinny Expert
  • 223 Answers
Hi you can buy a new or used 1 on ebay
Posted on Aug 21, 2010
6ya staff
SOURCE:
I bought a second hand Quinny Buzz, and the clip for the frame lock is broken
Hi
The transport lock is available as a spare part item - who did you speak with that advised you it wasn't?
RRP for the transport clip is 10GBP and you can order via your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Sep 11, 2012 | Quinny Buzz Baby Gear
The frame clip lock for quinny buzz is broken...
Hi
If you're in the UK a replacement transport clip for your Quinny Buzz can be ordered from your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) RRP is 7.50GBP and if ordered direct there is 3.99GBP additional p+p.
If you're not in the UK please visit www.quinny.com and select the country you're in, then choose the "Contact Us" tab on the right side of the screen for your enquiry to go through to the customer care team for your country who can help you source a transport lock.
Feb 02, 2012 | Quinny Buzz Baby Gear
How do u conect bassinet to frame of quinny buzz
You need to get hold of a pair of adaptors - they are sold on Ebay. They slot into the Buzz frame and then the carrycot locks onto the adaptors. The adaptors work for the carrycot and the car seat.
Search for quinny buzz adaptors and you will see what I mean!
Aug 19, 2011 | Quinny Dreami - Black Bassinet
Describe how to detach the adjustable handle bar for a quinny buzz
Good Afternoon
There are two little black circles just below the point of the handlebar where it extends - one front and one back, on either side of the handlebar. Push these in with a small point and extend the handlebar it will slide out of the chassis completely. You will need a second person to assist.
Jul 28, 2011 | Quinny Buzz Three Wheel Stroller
I need to find a new handle bar for the quinny buzz as the handle bar will no longer extend
Dorel UK 01842 763 281 (Mon – Fri, 8:30 am to 4:30 pm) are the UK suppliers of all spare parts for the quinny range and can supply you with a new handle bar. It's likely that the grey button (handle bar extender button) is broken. This pulls up the little studs on the underside of the handlebar allowing you to adjust. Its a fiddly job but can be done.
May 31, 2010 | Quinny Buzz Three Wheel Stroller
How to I collase a quinny speedi sx pushchair
f the dreami carrycot or the maxi cosi car seat are attached, these will have to be removed first. Apply parking brake Release the handle bars by unclasping the silver clips on the frame. Push down handlebar to lowest height as you press in the silver button under the quinny logo on the very top of the handlebar( in the middle of the foam padding) with a downward thrusting motion. The chassis should then collapse for storing. To unfold then release the transport clip on the left hand side with the red sticker on it and unfold upwards adjust handlebar to required height and lock by closing the silver clasps either side of the frame. If you want me to do a pic/video demo let me know. HTH
Feb 03, 2010 | Quinny Buzz Jogger
Unscrewed the air pump into frame. Did I broke my Quinny??
this will not effect the safety of this item x
you might be able to get this back to its original postion if you clase and fasten the pram and then try and fix this issue hope this helps x
you can contct dorel.co.uk by phone who are the only impoters and spares stockists fro quinnys in the uk and do fix faulty or broken quinnys there is a charge but would be alot cheaper than buying a new pram x
Oct 01, 2009 | Quinny Buzz Jogger
Clip on handlebar is broken
I would call them and see if they have that part if I where you. They should have it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 21, 2009 | Quinny Buzz Three Wheel Stroller
Quinny buzz
I had the exact same problem with my quinny buzz. When i went to get it repaired i was told that we had broken the gas line in the hydrolics in the frame. When i tried to collapse the buzz for the first time, when i got the the point where you meet some resistance (if you haven't pressed and pushed the buttons properly) i forced it closed which broke the hydrolics. This can't actually be repaired but the pram can still be used safely as long as you manually snap the frame up, ensuring it locks into place. The two black parts meet at the top when it's locked in properly so you should be able to see if it is or not. Make sure when you collapse the pram that you do press and push the buttons fully. You should meet no resistance and it should collapse freely when this is done properly. Hope this helps!
Aug 22, 2007 | Quinny Buzz Jogger
Quinny ZAPP Stroller Logo
369 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
doobuster
Tom Chichester
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
