Any 15-inch CRT-style monitor should be replaced by a 15-inch or 17-inch LCD-style monitor. You can find "previously-owned" monitors for $30 to $50, which is less than taking your CRT monitor to a TV/video repair-shop for an *attempt* to get it repaired.
It's time to spend $100 to buy a brand-new 19-inch LCD monitor,
or $200 to buy a brand-new 22-inch LCD monitor,
rather than paying a TV/CRT technician $50 to $75 per hour to try to fix the "antique" monitor.
PinSignal
1Red Video
2Green Video
3Blue Video
4Monitor ID - Bit 2
5Ground
6Red Ground
7Green Ground
8Blue Ground
9[KEY]
10Sync Ground
11Monitor ID - Bit 1
12Monitor ID - Bit 0
13Horizontal Sync
14Vertical Sync
15N/C (Reserved)
hi..i think you have a problem the CPU/Computer that's whystays on screen for so long.1st step check the IDE cable connection form the mother board to Hard Drive and 2nd check the memory or check all hardware`s.Good Luck and Have a nice day
The life expectancy is about 5 years. You can fix it, but it's not worth trying to track down the power board for a crt, it's going to cost you more than a new monitor. There are flat panels for under a hundred dollars now, you will save that on electricty over a two year period. Although some folks just like them better than lcd's that is no longer an issue, with the faster resolutions in the past few years you will be better off going for a new lcd. HP's website is the most likelly place to obtain service for your monitor, but I just got an email from Dell this morning and you can get a new 19 inch for about a hundred dollars from their reurbished shop if you really want to save some money, and a 24 was only around $200.
