This is the message shown when you power off your computer but you leave the monitor on. If your PC is on but you still see this message then it is a video problem. It could be as simple as a loose connection somewhere in your video cable (either where it plugs into the monitor or where it plugs into the PC). It could also be the monitor-many have different input modes and maybe the input mode changed somehow. Then again something could be wrong with the video card-are components loose on it? Check all of these, in that order (easiest to hardest), and I think you will have found the problem.
Hope this helps.
