If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing the water in my stackable washer and dryer wont - 2_bing.gifg src="/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
SOURCE: water keeps draining
You may be experiencing what is known as "siphoning". If you have your drain hose shoved too far down in the drain standpipe, or if you have the top of the standpipe opening sealed off, sometimes it creates a vacuum and will cause the washer to drain constantly drain. You need an air gap in order to prevent this. Double check your drain hoses for the following:
1. Make sure the hose is only placed in the standpipe about 3 to 4 inches. If it is sitting so far down in the pipe that it is resting in the trap where all the water is it will siphon.
2. Check the opening around the top of the standpipe where the hose rests. Makes sure there is still an air gap around the hose. That is, make sure the hose isn't seated so tight that it seals off the standpipe completely. This will cause siphoning.
3. Make sure you haven't placed anything around the standpipe opening. Many people will wrap old towels or wash cloths around the opening in order to prevent overflows and odors coming back up through the pipe. In doing so, they often inadvertently seal off the standpipe and cause a siphoning problem.
Last of all, the standpipe should be about 36 inches from the floor. If your drain line is sitting too low it can also cause siphoning issues.
I know I'm keying in on this drain line issue quite a bit here. There are some other things that can cause water levels in a washer to drop, but you mentioned nothing about any leaks and this is the most common problem. You will know for sure if you pull the drain hose out of the standpipe and suddenly hear a sucking noise. This is air being reintroduced through the drain line. I hope you find this information helpful.
SOURCE: Stackable Washer Dryer won't fill with water
hi
first thought would be water soleniods but it is unlikely that both would fail you could try just selecting one temp and then swaping hose and select the other temp if it wont work on either then i would think it is not a sol. problem, lid switch could cause it not to fill also but you did say it would spin so that will rule it out ,its coming back to a module problem ,something to ponder on
cheers grant
SOURCE: water wont drain all the way
I have the same problem and am trying to get it fixed. You can find good info here: http://www.applianceguru.com/
Search for the model name and number of you appliance. Good luck!
SOURCE: I have a sears 41799570110 stackable washer/dryer.
bad lid switch or clogged water pump-mike
SOURCE: my frigidaire stackable washer/dryer will not drain water or do anything past filling up
my washer fills up with water but will not drain
