0181 0182 0195 0235 0250 0303 0379 0380. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. http://electrohelponline.blogspot.com/
Try this link too http://remotesearch.blogspot.com/
I also have an LG TV. I used this 4 digit code: 0742. TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
press intreactive on sky remote move down to sky costomer service press select then move down to program remote ( 5 ) you will need make ( lg ) and model number of tv then follow on screen instructions
hope this helps
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998 Version 2: December 1999 Version 4: May 2001 (Sky+ introduced) Version 6: March 2004 Version 8: January 2006 (includes all current Sky+HD remote controls)
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206. This code was actually for a LG 42PX5D but it works perfectly on my tv.
