The drum light coming on should not stop you from printing. If the toner light is on it can stop you from printing.
Clean the drum chamber and the high voltage grid on the drum. Take it outside and use some compressed air on it. Regular cleanings work wonders on laser printers. Make sure you clean the laser window on the top of the drum chamber with a dry cloth.
Note also. You can easily test if it is a "replace drum error" by opening the door and pressing the go button until all the lights are on. That will reset the counter. If you're still unable to print then there is a more serious fault. The replace drum indication should not cause the machine to stop printing.
Replace the drum, if you have already and the light still comes on it is a common problem with these. I have 6 of them I deal with across two office buildings. There is a pile of 4 of them now we moved to a different model. I just don't want you to waste time/money on a goose chase.
