First, a scope of this grade will not be completely in focus as you move from one magnification to the next. But it should be close enough that you do not loose your point of interest.
Be sure you are not pressing down on the stage specimen platform as you change magnifications. It is very sensitive to pressure.
Also, be sure that the coarse focus tension is tight enough that the platform is not drifting down imperceptibly as switch magnifications. Look through the scope and watch if the image goes out of focus while you are watching it. If so, you have what is called "stage drift".
This is corrected by tightening the tension on the coarse focus knob.
The tension adjustment is on the coase focus shaft. It looks like a chrome ring with about 3 holes in it. There should have been a strange looking tool that came with your scope. It is used to adjust the tension. If your specimen is "drifting" out of focus, simply tighten the tension ring a little bit at a time until the specimen no longer goes out of focus. Do not get it so tight that it is not easy to operate the coarse focus knob.
