Power problem for the sony KLV-32U300A . Open the back cover of the tv onplug the power supply board, In primary section where u connect AC voltage just after the fuse there is NTC (negative temperature coefficient) parallel to the Relay, replace it. this could be the cure for your tv. isn't it simple? LET ME KNOW.
When tv will start after sometime when we off it will not start agin the power suplly will trip
I have the same problem @ Hong Kong, I still search for the method and the required unit...please help....tks!
more...and I got the totally same problem as the lzhouhao, the TV can be seen only i day after each time shut off....
the TV only bought 28 monthe b4.....
