Canon PIXMA iP1600 Printer Logo
Posted on Apr 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installing new ink cartridge, canon pixma 1600
How do I install my new ink cartridge for my canon pixma 1600 printer??? I cannot find my printers instruction manual!
Please please please help me!
Thanks!
  • 7 more comments
  • Eivis Jun 08, 2008
    how to instal canon pixma ip1600?
  • sandra_gail_ Jul 24, 2008
    I cannot put the new cartridges in the printer. Please help me.
  • Anonymous Mar 20, 2014
    wont read new ink cartridges
  • Anonymous Mar 22, 2014
    looking for a manual for pixma ip7260
  • Anonymous Mar 24, 2014
    if idon't have the user manual,i can't use the printer.
  • Anonymous Mar 25, 2014
    wont print once new canon ink cartridges are installed
  • Anonymous Mar 27, 2014
    Model 4425-004 lost instruction booklet
    and had taken the ink cartridges out months ago and now don`t remember how to install new ones.
  • Anonymous Mar 29, 2014
    user manual for canon mx526
    i don't have a manual for mx526
old marine
Level 3:
  • Master 2,426 Answers
  • Posted on Apr 17, 2008
old marine
Master
Level 3:
Answers
2426
Questions
0
Helped
951063
Points
10742
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
A
Anonymous
A
Anonymous
How to instal the canon cartridge?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 30, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2741
Points
How do I replace an ink Cartridge on a Canon Pixma ip1200
1helpful
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
My new pixma canon ip 2770 cannot recognize the black and colored ink
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
3helpful
I refilled my black cartridge of Pixma iP 1600. I have done it 3 times before and it worked perfectly until yesterday. Now when I refilled it the 4th time, the yellow LED blinks 5 times and then the green...
The manual for the PIXMA iP1600 says the following concerning the 5 blinks:
The ink cartridges are not properly installed, or a non-supported ink cartridge is installed (the ink cartridge EEPROM data is abnormal). Install the ink cartridges properly. Or, confirm that the supported ink cartridges are installed.
If you haven't already I would take a look at the electrical contacts on the cartridge to make sure they are clean (free of dust and ink) and then reinstall them in the printer. If the printer gives the same error, it's time to buy a new cartridge. 3 refills from a cartridge is not bad at all.
Hope this helps,
Steve
What is error e5 in mp 198 printer
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly..
  • In certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
  • 1helpful
    I put blue ink in a black cartridge and from then
    Hi, you shouldn't have done that, because the color cartridge and black cartridge are not of the same make, what you need to do now is to change the cartridge, get a new cartridge to replace to troubleshoot,let see if it will print.
    Compliments and wish you best of luck.
    3answers
    Both lights on printer flashing
    If you set to black and wite it should also print pictures by the way, it does not accept grayscale because it won't be able to print in grayscale photo quality.
    2answers
    Using refilled cartridges
    Are these chipped cartridges/ If so you will need to get hold a cartrisge re setter Most ink suppliers/manufacturers do them.
    old marine
    old marine
    ZJ Limited
    ZJ Limited
