Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hdghj
SOURCE: ice maker stopped working
pull the front cover off of the icemaker and see if the drive gear is broken (there are 2 tabs in the center of the gear make sure these arent twisted or broken as well) if so replace the module on the fron of the icemaker. if that checks fine check for frozen fill line..
SOURCE: Ice maker grinding sound
I had the same and found the same solution. Chances are the problem will come back. Just over a week ago (when it was freezing cold in Florida) I took everything out of the fridge and freezer, unplugged it, even pointed a hair dryer in the ice unit. Once I was done it was completely defrosted and dry. I have not heard anything since - and I can sleep again ;-).
SOURCE: maytag ice2o won't make ice
theharrisont, You state that...." ice maker stopped working after it flooded our kitchen floor." The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced. Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly). The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date. Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem. You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice. Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker. Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed. A hair dryer is a quick way to achieve this. Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker. Note: Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice.
This should correct your problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
SOURCE: Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
directly.
in refrigerator?
refrigerator?
These will help.
Thanks,.
