LG washer receiving an error of LE
Hello,This a common problem for all front loaders. Your washer will not drain
or work 'cause your outlet filter is clogged. Usually this small door
is on the left side front below of your washer. Expect some water to
come out when you open the door, etc. Clean out your filter and
refit.....things should be fine.
Thanks
Thanks for the tip! The manual said to call for service but it didn't take long to find a better option! I (a 45 yr old female!) popped open the little door and found a drain hose with a plug in the end. I drained all the water into a bucket and then pulled out the filter and cleaned off all the "gunk"! When I plugged the machine back in it worked fine! Sure beat paying $100+ for a service call!
We had LE display and followed advise on top cleaning the filter which was not particularly dirty but it did the trick. it washes as i type.
