2001 Kia Rio Logo
Posted on May 22, 2010
Torque specs for 1.5 kia rio connecting rod
Looking torque specs for 2002 1.5 kia rio for the connecting rod bearings and main bearings
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3587
Points
TORQUE SPECIFICATIONS kia rio
Cylinder Head Bolts:
(21.7ft.lb) or (3.0kgf.m) 90?
  • Anonymous Aug 25, 2010
    Connecting Rod Cap Bolts:
    (23.1~25.3ft.lb) or (3.2~3.5kgf.m)
    Main Bearing Cap Bolt:
    (39.8~43.4ft.lb) or (5.5~6.0kgf.m)
    (21.7ft.lb) or (3.0kgf.m) 90?? Loosen ?(21.7ft.lb) or (3.0kgf.m) 90?
2answers
What the torque specs. For a 2002chevys10 4.3vortex mains and rod bearing
Torque Specs Database
Type: Dim: Length: Head: Nut Grade: 20 Ft-Lbs 240 In-Lbs 27.12 N-m Connects: Connecting Rod To Engine Block Years: All Vote Record: Vote Note: Vortec - Rod Cap Nuts - 2 Steps: 20 FtLbs; +70degs
http://ww2.justanswer.com/uploads/ZZdaryl/2009-06-14_153454_torque.pdf
Main Bearing Cap Bolt 4.3L Step 1 15 ft lbs (20) Step 2 Additional 73 Degrees
i don't know if that's correct for main bearing caps since another link states it's much higher
4 3 Vortec Piston Specs eHow
hopefully a GM guy will chime in to confirm the main bearing torque
the rod bearing torques are the same on all the other links
2helpful
2answers
04kiaoptima 2.4crankshaft torque specs
main bearings torque is 18 ft lbs. plus 90 - 94 degrees, rod bearings torque is 13 - 16 ft lbs. plus 90 - 94 degrees.crankshaft damper bolt torque 80 - 94 ft lbs, fly wheel bolts torques 94 - 101 ft lbs.
Rod bearing torque for 1.6l kia rio 2005
The torque the the rod bearings is 40 - 43 ft. lbs (11.2 - 14.2 nm, 1.15 - 1.45 kg-m) hope this helps....
2helpful
2answers
I need to find the torque specs for the connecting piston rod? also the sequence and torque for the cylinder head bolts this is for a kia rio 2004 6cyl
22 - 24 ft. lbs. for the rod caps and....
110795143Cylinder Head Tightening Torque and Sequence.
Tighten cylinder head bolts in order shown.
Tightening torque: 36.1 ft. lbs. (49 Nm, 5 kg-m)
Loosen bolts in reverse of order shown.
Retighten cylinder head bolts in order shown.
Tightening torque: 18 ft. lbs. (25 Nm, 2.5 kg-m)
Mark cylinder head bolts for rotational reference.
Rotate cylinder head bolts 90°(1/4 Turn) in order shown.
CAUTION:
  • Do not reuse the old cylinder head bolts.
Torque specs
2002 2.0L Duratech.
Don't have 2004 2.3L
  • NOTE: Use new connecting rod bearing cap bolts.
    NOTE: Do not fully tighten the connecting rod bearing cap bolts at this stage.
    Install the bearing caps.
  • Rotate the crankshaft through 180 degrees and insert pistons 2 and 3.
  • Position the corresponding bearing shells, clean and free of oil, into the connecting rod and the connecting rod bearing cap.
  • Coat the inner side of the bearing shells with engine oil.
  1. NOTE: The crankshaft must rotate freely, if necessary check and adjust the bearing clearances.
    Tighten the main bearing and connecting rod bearing bolts.
    1. Tighten the main bearing bolts in two stages.
      • Stage 1: 25 Nm.
      • Stage 2: 60 degrees.
    1. Tighten the connecting rod bearing bolts in two stages.
      • Stage 1: 35 Nm.
      • Stage 2: 90 degrees.
3helpful
2answers
99 dodge intrepid specs
Inner main bearing cap bolts:
Torque to 15 ft-lbs, then rotate an additional 1/4 turn
Outer main (windage tray) bearing cap bolts:
Torque to 20 ft-lbs, then rotate an additional 1/4 turn
Main bearing cap cross bolts:
Torque to 250 in-lbs or 20.83 ft-lbs
Connecting road bearing cap nuts:
1helpful
Torque specs.
connecting rod = first pass 18 ft lbs , second pass 75 degrees
main bearings = first pass 37 ft lbs , second pass 77 degrees
wow that wasn't easy to find for some reason .
Top Kia Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Kia Expert? Answer questions, earn points and help others
