My frigidaire front load washer machine model# GLTF2940ES1 won't go through the spin cycle and leaves water in the bottom of the drum. If i manually select "Spin" it will drain the water still won't spin. It moves
My frigidaire front load washer machine model# GLTF2940ES1 won't go through the spin cycle and leaves water in the bottom of the drum. If i manually select "Spin" it will drain the water still won't spin. It moves when you wash
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
SOURCE: Frigidaire Model ltf2940es (Lowes) washes but does not spin
I HAVE THIS SAME PROBLEM . I HAVE LONG BACK GROUNG IN ELECTRONICS AND MECHANICAL WORKS.SO I DEICIEDED TO CHECK INTO MY PROBLEM I REMOVED THE REAR COVER AND I NOTICED THAT THE DRUM AND MOTOR ASSEMBLY HAD COME INTO CONTACKED WITH THE WIRING HARNESS EXPOSING THE WIRIES THIS COULD HAVE SHORTED OUT THE PROSSESSOR. I HAVE READ OTHER PROBLEM LIKE THIS ONE AND WHEN THERE REPAIR MAN CAME TO FIX ANOTHER PROBLEM THEN THEY TOLD THEM THEY NEEDED A NEW COMPUTER I THINK THEY KNOW OF THIS PROBLEM AND THEY ARE COVERING IT UP BECAUSE MOST PEOPLE DO NOT KNOW ANY THING ABOUT THIS.I HAVE MORE TEST TO RUN BUT I BELIEVE THIS IT THE ROOT OF ALL THESE PROBLEMS AND I THINK THEY NEED TO STEP UP AND ADMIT. THESE MACHINES COST A LOT OF MONEY AND WE SHOULD GET WHAT WE PAID FOR.
SOURCE: Frigidaire washes, but does not rinse or drain but it will spin
water pump is broken or not turning on
SOURCE: won't do spin cycle
http://www.servicematters.com/maytag_library/docs/16022808.pdf
http://www.repairclinic.com/Washing-Machine-Repair-Help
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
OK please find above a service and repair manual and a DIY washer self help site, with all this and the troubleshooting procedures in the manuals you should be able to isolate and repair.
