uncouple battery wait 5 mins reconnect put in security code, press up button, and it goes immediately to wait one hour. this seems to be a blocked state, what to do next?
You can't post conmments that contain an email address.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
These are the working Code Entry Instructions if the Renault does NOT have the Steering wheel Remote Control Keep pressing the Preset [1] until the correct first digit appears on the display Keep pressing the Preset [2] for the correct second digit
Keep pressing the Preset [3] for the correct third digit
Keep pressing the Preset [4] for the correct fourth digit
If the correct code is now shown on screen, press and hold the Preset [6] for 10 seconds to save it.
Note: If Preset [6] does NOT enter the code , then try Preset [5]
Losing the code after switching off usually means that the battery feed to the radio memory circuit has been disconnected.
There are two battery feeds 1..The permanent one to the memory (this retains the code + the station settings) 2...The main one via the ignition Switch that operates the radio itself
Have you been working on any wiring etc. recently.?
HI if you have the correct code, then pushing and holding the 6 button will give you one more attempt, if you enter the wrong code again, may as well put the radio in the bin .
make sure the code is correct!!
QHave you tried with failed attempts at all? I found this about the radio
I know I have the correct code but the radio
does not do anything when I try to enter it.
A
It is likely someone has tried to enter a
code or accidentally entered a number by pressing the radio preset station
buttons.
Most radios will enforce a delay between code entry attempts which increases
(doubles in some cases) with every try. These radios need to be left
switched-on,
completely untouched, until they are ready to accept the correct code.
Others give a maximum number of attempts - usually 10 to 13 tries after
which the
radio must be decoded.
Blaupunkt radios will often enforce a delay of 1 hour between code entry
attempts during which time be careful not to press any keys or the 1
hour waiting period begins again. The display should change after the
hour, indicating it is ready to take the code.
I will keep seeing if there is anything else that you can do
You need to leave you radio with pwr on for about 60 to 90 minutes,then the display will show CODE and you can try again,if you don't have the right code or nobody hasn't programmed any code try this number which is a master code for this model code 0100
good luck
Don't know company name,only Ford.
Made by VISTEON in Portugal
Visteon
tried that still comes up locked
what to do next?
