"OE" code in your washer indicates a Drain error.
This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
I have the OE display but it will not do anything, tried unplugging and then holding in the start/power butter for a 10 count. Also tried running just the drain cycle. Laid the drain hose on the floor, no water came out. Sure could use some help/ideas Thanks
SOURCE: LG washing machine displaying error
It's actually a DE error code which stands for drain error. Pull the
little basket out that's behind the small door on the lower left front
(where the drain hose is) and look inside. The drain pump intake is
about an inch in on the left. Make sure there's nothing in there like a
paperclip or hair pin. If possible reach in and see if you can turn the
impeller. If it won't move there's something in there if it will turn
then the motor is probably bad.
worked for me
got this from mark1963
SOURCE: LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
