Question about Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens
Autofocus stopped working
The autofocus feature stopped working on my Nikon 18-200mm VR lens. I tried cleaning the contacts with no luck. My other VR autofocus lens works fine on my D80 body, so I'm pretty sure it's the lens. Anything else I can do before sending it off to be repaired?
  • 176 Answers
I fix these all the time for this problem, The focus motor is bad, Tony
Posted on Jun 04, 2010
6ya staff
SOURCE:
LOOKING FOR A Nikon Normal AF Nikkor 50mm f/1.4D Autofocus Lens WITH VR.
There is no such thing. You can see a full list of current Nikon lenses at
http://www.nikonusa.com/Find-Your-Nikon/Camera-Lenses/index.page
You can see a list of current and old Nikon autofocus lenses at
http://www.bythom.com/nikkordb.htm
You'll see that no 50mm Nikon lens has ever had VR.
Sep 28, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
Autofocus stops after heavy usage
Maybe cleaning the gold coloured contacts on the back of the lens and the ones in the camera may help. Worth a try!
May 12, 2010 | Tamron 18-200mm f/3.5-6.3 for Nikon
Autofocus does not work
I fix these all the time for this problem, The focus motor is bad, I charge 145.00 to fix these, Tony
May 11, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Lens has lost ability to autofocus.
Nikon guarantees 5 year warranty to original purchaser. If your camera functions with another AF-S lens, then the problem lies with the 18-200mm lens. The AF motor unit needs replacement. Nikon should be able to repair the lens under warranty.
Make a copy of your receipt and go Nikon website to start repair service.
May 08, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
My Nikon D80 will not autofocus
Fix your issue with these steps:
1. Try forcing the lens to rotate a fraction of a inch. This will sometimes help the problem. Or simply move the switch from M to A on the lens.
2. Try to switching to a single of the 11 auto focus points. Then try if there are specific points that are the problem.
3. If all auto focus points are fine, try updating the firmware or cleaning the sensors inside the camera behind the mirror. If a one or more points are out of order, also try cleaning the sensors behind the mirror.
4. Detatch the lens from the camera, by applying pressure on the release button and twisting the lens so it can be released. See picture
5. Set the camera selection wheel to manual (M), see picture
6. Turn the camera on, and start the liveView format. This will flip op the mirror inside the camera.
7. Take a dry can blower. Or if in lack, use an empty plastic bottle, without moisture inside, and use it to blow on the autofocus sensors.
They are located at the bottom under the mirror. NOTE Do not blow with your mouth, small amount of moisture will hit the CCD also located here.
8. Turn the camera off
9. Reattach the lens. Push the lens, white point to white point and turn the lens in place.
10. This worked for me, hope it also helped you ;)
For more solutions check Nikon D80 Manual
Apr 03, 2017 | Nikon Cameras
Unable to get my Nikon D200 to autofocus. Nikon 18-200 VR lens mounted
Clean the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Sep 23, 2009 | Cameras
My nikon 70-200 stops focusing
Nice lens too... I would take a good look at the electrical contacts on that lens. If OTHER lenses are truly working correctly, you have eliminated the camera as the cause and need to look at that specific lens. The first thing that I would try is taking a pencil eraser and rubbing all of the contacts with it. This will often clean the contacts of dirt and grime and clear off any "coating" that may have accumulated over the metal portion of the contacts. Barring this, I would send the lens to Nikon for servicing. It is a high percision device and taking it apart yourself is NOT recommended.
Jul 10, 2009 | Nikon D70s Digital Camera
Sigma 70-300 Macro Motorised Lens for Nikon has stopped autofocus
If you just purchased the lens I would take it back sounds like the lens is jarred and defective should still be on warranty
Jan 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens Logo
492 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
