Do you have a solution to a Ricoh Afcio 350 error code 326-00 problem. If so can you e-mail it to [email protected]
Thank - You,
Morgan
The laser unit of 450 is not compatible with 350, It is going to copy but the copy will be deformed.
SC 326: Laser synchronization detector board cannot receive the laser beam.
Replace the laser sync detector, Part No. A2935310.
Or try the following solution;
Open the front cover and remove the brown inner cover - 2 screws.
The black unit after the inner cover is the laser unit. There are 2 screws securing the laser unit - loosen them.
Tighten the right securing screw while jacking up the right side of the laser unit with a screwdriver.
Tighten the left securing screw and put the inner cover back on.
If SC 326 is still indicated after the above procedure, replace the laser sync detector or the whole laser unit.
Good luck and please rate me, thanks.
Hello Morgan,
Your copier has two lasers that are used to write the image of the document you wish to reproduce. The second laser is used for higher definition(DPI) for example a high quality print job. A single laser is for your run of the mill copy stuff. E- 326 means there was error regarding the function of the second laser. Theoretically, the simple function of making a copy should still be available to you once you have reset the error code. You can do this by powering off the copier using the switch located at your left knee, or if in doubt, unplug the copier for a moment. Here are the nuts and bolts of the problem. There is obviously a problem with the laser unit unless it was a fluke.
Press the {User Tools/Counter} key.
The User Tools Main Menu appears.
Enter {2} with the Number keys.
(is this what you are looking?)
Spinal,
I continue to get this error also. If I power off the machine, the error code comes back on. What would be the long term fix? Is it expensive?
Thanks
Any help please? I got the same functional error SC360-00 for my Aficio 350e. Tried the power on/off but the error came back.
Brando
Hi help needed from experts out there,
My Aficio 350e's laser unit is defective and have tried replacing it with a 450 laser uinit. Before replacement it does not copy. After replacement it seems to be working now (copying) but my problem is that the width of the copy is reduced by 50%. The length is ok. Is the laser unit of the 450 compatible with my 350e machine?
pls help,
Brando
