Question about Dryers
Electric dryer no heat (tumble works)
Hi there.
I have an older model Eaton viking 5 dryer that has stopped heating. I believe it may be the thermocouple? on top of the drum (underneath the top cover) or the heating elements.
The machine still runs on all modes but just no heat. Any suggestions?
  • 725 Answers
Do you have an ohmmeter or voltmeter? check them for continuity it will tell you if there are good or not?
Posted on Apr 06, 2008
6ya staff
SOURCE:
Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
May 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryer tumbles but does not heat up, there is little heat when it tumbles without any cloths in it.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Dryers
Dryer will turn on and count down but will not start to spin or heat up, model med6600tqo
heatman101
Apr 28, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My dryer quit heating and doesn't quit. It keeps tumbling non stop but with no heat.
heatman101[[]
Apr 20, 2011 | Crosley CDE6000 Electric Dryer
MY DRYER HAS STOPPED HEATING,STILL TUMBLES FINE BUT NO HEAT,IS THERE A RESET ON THE THERMOSTAT?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 09, 2010 | Dryers
Maytag performa dryer model-pdet920ayw will not heat. drum tumbles and timer works
heatman101
Sep 20, 2010 | Dryers
Kenmore dryer thats not drying
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Dryers
Dryer heats up then stops but drum still tumbles
heatman101
yrwht
Jan 10, 2010 | Whirlpool LGR5636L Gas Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Dryers Logo
391 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
