My dewalt DW9116 battery charger lead light is flashing rapidly when I insert battery for charging what does this mean?
Brown
Brown
Silver
Gold
R21 = 0.11 Ohm at 5 percent
Now can someone help me find the schematic for this model? DW9116
[email protected]
On 3/5/12
I am having the same issue, i.e. the charger light is flashing rapidly. rdohn, is there any way you could provide a tint of instruction on how exactly to change/re-solder the large capacitor inside?, i.e. maybe how to identify it and go about doing this job? Sorry, I'm not too adept in such matters, so any advice would be great.
Thanks.
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
SOURCE: CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
SOURCE: My Dewalt 7.2-18v charger model #dw9116 is giving
It means there is too high or too low a voltage coming into the charger. Check your chord.
I had the exact same problem. After using the necessary security bit to crack mine open, I found that the large capacitor inside had come loose and needed to be re-soldered.
That fixed my charger.
