In the interior window of the Kitchen Aid KGRT607 cracked during broiling. KitchenAid Customer Service gave me part # for the wrong glass (there are 4 glazings - double paned inside the stove door (the one in the oven side is the one broken), a glass glazing that slips on the outside of the oven door which is covered by the various trims, and the exterior glass framed by the stainless steel sheeting trim.
Does Kitchenaid have repair manuals on this model stove?
RP
San Diego
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
I have the same problem. the inside oven pane cracked while cooking a pizza. Need to find a replacement now.
