Brother HL 6050 Laser Printer Logo
A
Anonymous Posted on May 21, 2010
Brother HL-6050DN Printer gives "replace laser scanner unit" message on led.
Tareq Bin Mostaq
Level 2:
Champion:
  • Expert 205 Answers
  • Posted on Jan 11, 2018
Tareq Bin Mostaq
Expert
Level 2:
Champion:
Answers
205
Questions
5
Helped
112276
Points
323
Need to reset .Open the front cover .hold the go button power on all lid on than press 7 time .on off printer may be reset.
Swarnava Palit
Level 2:
New Friend:
  • Expert 114 Answers
  • Posted on Jul 21, 2010
Swarnava Palit
Expert
Level 2:
New Friend:
Answers
114
Questions
0
Helped
63936
Points
187
The problem coming because the laser unit in your printer is not working . Need to be replace laser unit to solve the problem.
6helpful
Brother HL-6050dn Toner Life End Message Tried covering the eye Tried Go-Set and changing to Nothing solution Still red message saying Toner Life End
I just got through this problem, The customer had a "refilled cartridge.
The Flag on the left side near the gearset of the Toner cartridge was not
brought back to the proper position, just undo the three srews and reset the flag.
works like a champ,. your welcome.
13helpful
Reset drum unit counter brother hl-6050-dn
Press the "Go" and "+" switches together until the menu "RESET
PARTS LIFE" appears on the LCD display. Select the Drum Unit using the "+/- " switches, then press the "Set" switch
1helpful
2answers
Service manual for a Brother HL-6050DN Laser Printer
Hello Sir, You can get the Service Manual for you printer at http://www.smpcshop.com/HL-6050-HL-6050D-HL-6050DN-p-4010.html
You have to get it for a nominal price of $9.95.
Thank you Sir, Have a nice day.
3helpful
2answers
Paper Crinkling
you change your printer fuser unite solve it
Printer will not print
Wrong driver?
I've seen Brother printers that won't print with a replacement driver of another Brother printer
(a common PCL5e driver always works -> HP Laserjet 4L)
Black track on the printed papers
Bad drum
(or sometimes: a little part of a previously jammed paper that blocks access of the laser beam to the drum)
2answers
Toner end of life
press Go and Set at exact the same time
press < one time
press Set
choose "Nothing"
press Set again
Brother sold me replacement part but will not give instructions
Hi, it looks like you have to pay to get a copy of the HL-6050 service manual. SMPCShop.com sells it for $9.95, or Service-Manual.net has it for $12.99, including a parts list.
Hope that helps!
Norman Weimar
Norman Weimar
k24674
