Reebok 8050 ES Treadmill Logo
A
Anonymous Posted on May 21, 2010
Dumb question my friend just gave me her treadmill. I plugged it in but don't know how to turn it on. Where is the on button?
John Mazmanian
Level 3:
President:
  • Reebok Master 832 Answers
  • Posted on Jun 01, 2010
John Mazmanian
Reebok Master
Level 3:
President:
Answers
832
Questions
0
Helped
628616
Points
2056
Go to iconservice.com go to manual input this info RBTL071070 - REEBOK 8050 ES TREADMILL a manual is their to down load.
My cousin gave me a treadmill that had a problem. I am hoping to fix it instead of buying a new one. At low speeds (1-2) the belt will not turn but at 3 and up it operates fine. I don't know if this is...
RUN the software calibration, go under the HOOD cover motor and follow the steps and fix it. Or read your owner manual or download from www. fitness.manualsonline.com
God bless you
1helpful
Cannot turn on proform 380 cs treadmill
1) test the outlet wall with a desklamp, if the lamp turn On THE circuit is o.k otherwise, the problem is fuse blown or c. breaker tripped, reset or replace fuse.
2) test the power cord for open or faulty. with VOM usin continuity
3) test the fuse y/o c.breaker inside of machine and reset or replace.
4) Turn on the machine if the machine keep the same simpton, test the key(magnet) the key is a magnet, test vs your magnet from seal magnet of your refrigerator for atraction or repulsion, if doesnot pass the test replace the magnet from some hardware like home depot.
and PROOF again, can be work. see the block,
Otherwise if the problem keep you must call some tech profesional, maybe you have Main switch open or defective and need replace, or power supply, capacitor, transformer, etc defective. or faulty.
God bless you
A friend gave me this dishwasher with this model number and I don't know where to connect the drain line
i recently installed a dishwater and had to hook the drain up to my garbage disposal line and have no problem
1helpful
I plugged it in and it will not start. It was working fine yesterday but now nothing.
Did it possibly blow a fuse in the treadmill? Also, Check your circuit breaker as well, and see if a circuit blew that was dedicated to the outlet.
Read the user manual of your treadmill to find the elevation motor. The treadmill fuses are located inside the elevation motor. If you don't have the manual, contact the manufacturer of the treadmill and ask if it can send you one or if there is one you can download online.
Turn off the treadmill and unplug it. If you have recently used it, let it cool down for one hour before opening.
Place the treadmill on its side and use a screwdriver to unscrew the lid off the elevation motor. Carefully remove the fuses. Some treadmills have easy access to internal parts where you don't need a screwdriver. If this is the case, simply lift the lid off.
Take the faulty fuses to a hardware store to make sure you purchase the correct replacement fuses.
Insert the new fuses into the elevation motor and close the lid. Plug in the treadmill to see if it works.
My friend gave me a Kettler Boston XL Treadmill (Germany) a month ago I only realize i m missing some info. Can you let me know what is the voltage for this brand. Fyi this unit was used on vessel and i hv...
there should be a model tag on the machine , probably down near the belt , that will have the voltage details for the motor
if not the plate on the motor will have the voltage , rpms, watts and cycles plate on it
Won't turn on at all.
If you have no lights, check the main harness that cary power to the console. Check connection at both ends.
PS Always check outlet to make ssure you have 120 volts.
Friend gave me Iphone said it was "broken" she is dumb
you need to perform a force recovery mode. to do this hold power and home screen buttons until the screen resets when it does keep holding the home screen button and plug in the phone to the computer after a few seconds itunes should see a phone in recovery mode and force you to do a restore. if that does not work you might have a hardware problem and will need to go to a store.
Top Reebok Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
