LG WM-2277HW Front Load Washer Logo
A
Anonymous Posted on May 21, 2010
My front load washer had ue blinking after a load was supposed to be finished. The clothes were soaking wet like the washer didn't spin
nomess
Level 2:
  • Expert 343 Answers
  • Posted on May 24, 2010
nomess
Expert
Level 2:
Answers
343
Questions
Helped
101341
Points
753
UE is imbalance error...Usually because a load in the machine is unable to distribute itself around the inner drum, and the machine senses the load as imbalanced.....Good Luck Nomess
Kenmore elite will not finish a wash. every load no matter the size has a UE code. Please advise.
the ue code indicates that the control detects an unbalanced load in the washer that cannot be redistributed. press the start/pause button and try to redistribute the load. here are some problems that can cause this error code
the washer is not level or not stable. make sure that the washer is leveled properly front to back and side to side. press down on opposing corners to make sure that all 4 feet are firmly on the floor. adjust the leveling legs if necessary.
WASHING TO SMALL A LOAD
laundry can sometimes gather to one side. redistributing the load manually can resolve this issue.
try running the washer without any items added and see if it will spin properly. if not, you could have a problem with the control board or the hall sensor on the motor that detects motor speed.
uE error code 79631512210 Kenmore Elite Washe
UE Error Code on LG Tromm Washer
From back or underneath, check that all three shock absorbers are attached. Take top off and check if both springs are in place and un broken
What does"ue " mean?
UNBALANCE ERROR - Display shows UE.Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
1helpful
Cannot open the door
'UE' adalah menandakan " unbalance error ", solusinya adalah set kembali posisi mesin cuci anda jangan sampai miring atau seimbang dari permukaan lantai. jika sudah dianggap seimbang, coba hidupkan kembali mesin cuci anda dari proses pertama.
1helpful
WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
Error code UE
UE Refers that the Unit is Unbalanced. Take out the clothes out of the washer and then Run the washer. Does it Spin?
If yes, then it might be Unbalanced Load. Try to Load Small Clothes. If not, or if the Error is Appearing again and Again, Control Board or the Sensor is at Fault. You cannot Test the Control Board or the Sensor but usually Sensor is the Common Problem with Most of the LG Washers.
So, First Change the Sensor. If Problem Persists, Change the Control Board. On Most Models, Sensor would be Located near the Front of the Unit on the Side of the tub.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
17helpful
LG front load washer coded UE. what does that mean?
UE means unbalanced error. when you see this, it means the clothes are unevenly distributed in washer, it's basically unbalanced.
2helpful
2answers
Comes up with the sign UE ??
Hi
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
2answers
Error Message and Tub not spinning
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
