Re: MY PHONE CHANGED LANGUAGE FROM ENGLISH TO SPANISH...
All you have to do is start your menu from the begining, in timing advance to the language menu(if possible refer timing with the manual) scroll down and select- Anglais, press ok, there you are.
1. Open Menu
2. Go to the "Ajustes" (it's Settings on spanish)
3. Click and open Ajustes (Settings)
4.Scroll to the "Lengua" (it's spanish word fro language)
5. Press and choose English
Hope I was helpful.
Start > Control Panel > Clock, Language, and Region > Regional and Language Options.
Once in the Regional and Language Options, click the Keyboards and Languages
tab. If you see a drop down list of languages, see if it is set to
English. If not, set to English. However, if you do not have this list
there, you may need to install it.
The problem is not from the battery you changed. It should be from the sim card you changed. The phone's language is set to automatic, therefore it reads sim card languages automatically. To rectify this, since you do not understand spanish: Option 1 -Put back the english sim then go to settings, and set your default language to English only
Option 2 -Send me your phone name and model so I can give you a reset code THANKS. HOPE THIS HELPED.
go here and make first language english and next SPANISH
follow this pattern settings->phone settings->language settings ->phone language->english type this word by word in translate and do it in your phone it will be back to english...
Display Language
You can select either “English” or “Spanish” as the display language. The factory
preset is “English”.
• If you select a language you cannot read, change the display language again
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [up]
or [down], then press Select.
3 Scroll to “Change language” by pressing [up]
4 To change from English to Spanish, press
Español.
To change from Spanish to English, press
English.
• The display changes to the selected language.
• You can also select a language by pressing [up] or
[down].
5 When Spanish is selected, press Salvar, then press [OFF].
When English is selected, press Save, then press [OFF].
Oh boy that's a real problem. I guess the menu is there but you don't understand it because it's in Spanish.
I don't know this particular phone but thinking logically, there are four things I would consider.
1) Find someone who can speak Spanish, there are lot of people who can.
2) Find someone who has the same phone that is in English and copy the key presses.
3) Use Google language tools to help you interpret the Spanish menu
4) Take you phone to a dealer
