Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
Where is the ballast located on the RCA Scenium? I have a 61", replaced the lamp in early Feb. 2010 and now we have no picture but do have sound. I checked previous posts and found an answer, the ballast or the DMD corad, which i do not thisnk this is. Is it feasable to replace this ballast on our own? If yes, where is this located in the TV? Thank You
6ya staff
SOURCE:
tvtek
Duke
  • 1284 Answers
SOURCE: No picture
Assuming that the replacement lamp is good, you could be looking at a bad ballast (lamp power supply) or the switch on the lamp door itself could be causing the issue. The light engine also could cause an issue like that. I would have a technician look at it as this is beyond consumer repair.
Posted on Nov 26, 2007
Anonymous
  • 74 Answers
SOURCE: projection lamp burn out
well look at this,, I use many projectors due to my work with artist and my bussiness in wedding and happybirdays,I have to chage those expensive lamp frecuenly. a cople of time the lamp fuse off rapily in short time and the store is ok no buddies warrant electric or electronic parts so we the custumerpay for the in line manufacture bad parts so nothing to do buy another one and thats all you can do but clean the soket and allway look for crack or weare parts in the socket I use to inspect everything in the lamp system specialy the socket and clean the contatc were you conect the lamp with a very thinn sharper tool if you suspec change the lamp socket they always work at verry high temperature ....good luck and rate me
Posted on Jan 05, 2008
Robert Johnson
  • 395 Answers
SOURCE: The picture on my RCA Scenium HDLP61W151 61 in - was completed black
unplug both the TV and the cable box for 2 minutes then replug them in. this will reset the micros in both units. if there is still no sound check your SAP setting make sure its off.
Posted on Feb 06, 2008
Anonymous
  • 6 Answers
SOURCE: RCA Scenium
Sounds like a cold solder joint in the power supply or faulty capacitors.
Posted on Mar 30, 2008
Anonymous
  • 18 Answers
SOURCE: dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Posted on Jan 15, 2009
I have a hd61lpw165 big screen tv that makes a loud buzzing sound as soon a it goes on with no picture.
sounds like the lamp or ballast, check the lamp first to see if good, then if good, then probably the ballast is bad, but I think the sound or buzzing is coming from the ballast, so it's should be good.
Mar 04, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
No picture/sound
YOU HAVE AN INTERNAL TUNER FAILURE IT NEEDS TO BE REPLACED
CONTACT RCA FOR REPLACEMENT PARTS OR INFORMATION
here are some contact information for rca
http://www.rca.com/content/viewdetail/1,2811,EI45168,00.html
Questions about operating or setting up your
HDTV: Call us toll free at 1-866-SCENIUM
(1-866-723-6486), or send us an email.
Quality comments? Call us toll free at
1-866-SCENIUM.
Jan 06, 2008 | Televison & Video
My RCA Scenium picture just went black out of no where. I can still hear sound, it will change input but nothing shows up on the screen.
Take the Lamp out and see if it is shattered. The access door is on the left rear of the set. Chances are the lamp is the problem. The Lamp cage has the part number on it.
I hope this helps,
Skyassoc
Dec 26, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
The picture has gone black the sound still comes through but no picture ??
Probable failed light source (lamp). These are available from many sellers; expect $100+ US and shipping.
RCA Replacement lamps
Nov 29, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I replaced bulb, I have sound but no picture. There is no light in rear of T.V.
If bulb is new, try resetting bulb life timer by owners manual, If needed, test and/or replace the ballast which controls power to bulb.
Sep 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Dark picture!
The Lamp it self, the Ballast, or the Power Supply that powers the Ballast. Even a combination of the Lamp and Power Supply is a common problem. If you have not replaced the Lamp since you have owned the set I would replace that first. The Lamp has about a 3000 to 5000 hour life span.
Hope this helps,
Skyassoc
Jul 16, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Rca lamp replacement, still no picture, power light still blinks.
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
Jun 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Feb 06, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
No picture
Nov 25, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Buzzing noise, sound but no picture
It sounds as if the lamp needs to be replaced. The buzzing sound you hear is the ballast attemting to fire the lamp.
Oct 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
266 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
