Miele S4210 Carina Bagged Canister Vacuum Logo
Posted on May 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Miele vacuum dust problem
My Miele vacuum is about 20 years old and the room smells dusty after vacuuming. I have changed all filters. Is there a solution?
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on May 24, 2010
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801341
Points
33142
Hello. The problem you are having can be rectified with the new Miele FJM bags.
http://www.mielevacuumbags.us/
Also, if you have never taken your machine into a vacuum repair shop for an internal cleaning, please do so. J.
Miele Silver Moon Losing Suction Power
That is possible, also check for a.m. exhaust filter off the motor. Usually a very fine filter to stop dust that gets past the bag. May just need to open it up and clean out the accumulated debris.
Blowing dust out even after cleaning filter
the bagless containers of these vacuums do tend to hold a strong dust odor. the only way ive found to help eliminate it is with a product that i use called FreshWave odor neutralizing pearls. you never want to use fine dust carpet freshener or any product like that cause it will eventually burn up your motor. but if you are interested give me a call and i can ship you some of the freshwave. 703-724-1112
Noisy vacuum that wont pick up properly
Your vacuum is still under warranty. Call Miele or the Miele dealer you bought it from. They are obligated to repair your vacuum.
3helpful
Hoover Vacuum Cleaner Bad Smell
change filters. the filter inside the unit and the one on the side needs to be changed once a yr. (these are not to be washed, only the side filter if foam can be washed ). also flat belt change every 6 months and the v-belt once a yr.
Can you replace the cloth bag in a beam central that is about 20 years old, the vacumn sends a dusty smell though the house
It is not recommended to change that bag. The best thing to do would be to borrow a shop vac from someone and vacuum it off really good. The bags sell for about $60.00 and they are a big pain to change out. The other thing you can do to help the odor is look into exhausting the unit outside. All manufacturers recommend it.
2answers
Dust smell when running g4 kirby
The dusty smell coming from my G4 finally drove me to search out the problem. As it turned out, the fill tube had cracked near the top of the mini emptor (the boot) and dust and crumbs were escaping from the tube and into the cloth bag. I tried to repair the split with duct tape and electrical tape, but to no avail. I finally gave up and ordered a new fill tube online for about $8. This took care of the problem, and the machine works like new with no more dusty smell.
Dusty smell
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41018&thid=618510
Dusty smell
Posted by chekle on May 23, 2008
I buy loads of Hoovers and always same problem. When I Hoover its a dusty smell and it stays around bag not full and check filter the Hoover is ok f couple days then this happens.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5881-900 Vacuum. It sounds to me that if you have a clean bag and filter, it sounds like you have dust in the motor section and it needs to be cleaned and or take a good blower and blow out the dirt or you may have a clog or dirt build up in the suction line and that might be causing the dusty smell. Please feel free to contact your local vacuum cleaner dealer in your area or call the Hoover factory and ask for tech support. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Top Miele Vacuums Experts
john h
Ngoro
jws1013
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
