Question about Samsung S860 Digital Camera
Installed driver (under Windows xp) for Samsung S860. Connected camera to computer. Computer does not recognize camera. What else could I do to let it work?
  • Samsung Master
  • 4,928 Answers
Bypass Samsung Lock Screen Pattern, Password, Pin and Fingerprint Without Data Loss
broken Samsung Galaxy data recovery software is your ideal choice to unlock Samsung without password in minutes,no more series steps,no more security problems.This helpful program is used to solve Android locked screen problems effectively.Now the latest version currently supports Samsung devices only.
It can help Samsung users disable the password and pattern lock issues on Samsung device without data loss,afer remove the phone's locked screen,you can access your contacts, SMS, pictures, emails or other important data.The program applicable Samsung device including Samsung Galaxy S9/S8/S7/S6/S5/S4/S3,Note 7/6/5/4/3,etc.
LEARN MORE
Posted on Oct 12, 2019
  • 10,421 Answers
6ya staff
SOURCE:
When I am connecting my Samaung Digital model S860 with PC having Windows Xp (Profectional) via USB cable, nothing is happening at PC screen. Also I don't have driver CD with my camera. Please sen
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 08, 2013 | Samsung S860 Digital Cameras. 8-megapixel...
Hi, my samsung n130 netbook webcam is not connected, what can i do??? where can i download the driver or controller??? when i run the cyberlink youcam apeears a message "no video device...
You can download the drivers from the manufacturers website. then you will go to the download drives section and look for your computer model and download the driver.
Mar 01, 2011 | Computers & Internet
I need drivers for my samsung s860 camera
you can download the drivers for ur camera from the below link...
http://www.samsungcamera.com/customer/download/cus_down_main.asp?key=s860
a very helpful rating is appreciated for answering your issue...
thank you
Aug 10, 2009 | Cameras
Having problem transferring photos from camera to pc
connec the usb cable to ur pc and then open my computer.
you shall see a removable disk double click that.
then click on the folder called DCIM and you can find all ur pics there.
select whichever you want and drag and drop them to the location you want them on the computer.
issue resolved.........let me know if u have anymore queries.
also you dont need the software installed only the drivers for the usb cable need to be installed
Jun 19, 2009 | Samsung S860 Digital Camera
A Sumsung S860 camera & havin a hard time finding usb driver
you do not need to download the drivers when you have an XP , the unit is suppose to be plug and play for Windows
try this
>turn the unit OFF
>CONNECT the unit to your PC
>TURN the unit ON
>a selection should be displayed
>pick COMPUTER
>the computer should detect the unit as a REMOVABLE DEVICE
>open REMOVABLE DEVICE
>open DCIM folder
>there should be folders inside DCIM named SSCAM100, SSCAM 101, ....
>your pictures should be inside those folders
*each folder consist of 100 pictures that you have taken
*the camera automatically creates each folder for every 100 pictures that you have taken
hope this helps
Jun 15, 2009 | Samsung S860 Digital Camera
S860
you do,not need a driver to tranfer pictures from camera to pc,first make sure you turn camera on,highlight the words camera,click ok on your camera.the download should start,if it does,nt start you need some kind of print programs.they should help you access your pictures,also if the computer recognizes the camera as removable media. you can go to my computer,right click on it,click open and look for pictures.good luck. hope i helped
Apr 22, 2009 | Samsung S860 Digital Camera
I need to download a driver for S860
The computer does not talk to the phone,it only see the card that is in the camera.
So a card must be in the camera for the computer to see it.
It only uses a usb driver to see the card, so xp and vista should see it. After you plug in the camera windows will pop up a little window
and say something,like,found new hardware, installed, could not install.
If you go to the website of samsung, you will see that the only driver they have is for win 98, that is because it only uses a usb driver like I said,and xp and vista already use these drivers.
Mar 29, 2009 | Samsung S860 Digital Camera
Hey
in almost any case, you shouldn't need additional software to copy pictures from your camera. If you're using windows XP or newer, just plug in the USB cable and turn on your camera. A new drive letter should appear under your start menu--> "my computer".
probably named "removable disk G:" or maybe a different letter.
double click in there and voila. your pictures are in a folder somwhere in there, in a subfolder.
Jun 06, 2008 | Samsung S860 Digital Camera
PC wont see my Panasonic NV-DS50
Generally when you connect the camera via USB Windows XP and Vista activate native drivers and the camera becomes visible under "My Computer" (XP) or "Computer" (Vista) as a removable drive. However, probably will not be visible by capture software. In that case you would need to use a DV interface cable otherwise known as firewire and have the camcorder in playback mode.
Mar 04, 2008 | Panasonic NV-DS50EN Mini DV Digital...
Samsung S860 Digital Camera Logo
655 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
