Hi I'm contacting you because I had a question regarding my Sony Digital camera. I had taken the camera into a geek squad in Mid December because they was making this grinding sound and would shake the lens and take blurry pictures. Back then I had insurance on the camera and the insurance covered the costs. The same thing is happening now to my camera but this time my insurance is expired. I was wondering because it is happening again would I be able to have it fixed at ***? Or am I out of luck and possibly having to pay out of pocket.
I think you can make a very good case for the geek squad being unable to completely fix the problem, or it would not have come back. You may have to take it up with progressively higher levels of management, and maybe even threaten to contact local news media that comes to the aid of consumers. Once in a while there's little you can do but give up, but make no mistake... if they don't help you, they want you to give up and go away! Whether you get them to make a fix or not will largely depend on your tenacity in being a "squeaky wheel", if you know what I mean. Good luck!
SOURCE: "Turn Camera On and Off Message"
go to http://www.pechorin.com/m/2006/08/24/Re_Sony_DSC_W5_lens_problem-270736.html it will tell you how to fix it at no cost :) and it works
SOURCE: Flickering LCD screen on Sony digital camera DSC-T1
Camera has problem in CCD Imager and this part needs to be replaced. Sony has scheme to repair it free of cost. Please click Sony Support for details.
Regards,
SOURCE: shaking optics in sony DSC T300
Hi!
It's faulty stabilizer. The lens unit has to be changed. Contact your local Sony service center, but
if they ask too much, you can contact me at [email protected]
and I will give you a good price.
I work in Sony service center.
Tom
SOURCE: SONY Digital Camera DSC-W50 doesn't work. Lens goes in and out...
Hi!
Please try the under given troubleshootings:
(i) Please check if the Battery is fully charged.
(ii) Next, turn off the Camera, remove the Battery pack then press and hold the Power button for 30 seconds.
(iii) Then, reinsert the Battery pack and turn ON the Camera.
(iv) Next, try to access the menu options either by directly pressing the menu buttons or while reviewing the images.
(v) If the menu options are accessible while reviewing the captured images then reset the Camera to the original factory settings.
Please follow the steps given below to reset the Camera to the original factory settings:
(a) Turn ON the Camera.
(b) Access the menu screen either by directly pressing the Menu button or pressing the menu button while reviewing the captured images.
(c) If menu screen is accessible, then press the right arrow on the Control button to select (Setup) Settings, then press the right arrow again.
(d) Next, select the Setup 1 option by using left/right/up/down arrow on the control button.
(e) Then, select Initialize and OK.
(f) Finally, follow the on-screen instructions to set the clock in the Camera.
Performing the above steps will reset the Camera to the original factory settings. If the issue persists even after performing all the above steps successfully then the issue is related to hardware malfunctioning and service is required.
Please feel free to contact for further information or any clarification.
SOURCE: sony cybershot dsc-h7 -vibrating image, binding noise, blurry pic
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com this is spam mail so be prepared to wait a few days for reply.
