SOURCE: Kyocera cs1820 has unknown id
Refer to the Advance Operators Guide page 6-1. You can download the manual at the following link; If yo need additional help call Kyocera Technical Support Monday - Friday 9 am - 6 pm EST at:
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14173&rid=14774.
1-800-255-6482 There is no charge.
SOURCE: CS-1820 admin password reset.
The master user name is 1118 and password 1118 also. this should give you access to the menus and allow you to do whatever changes you feel like.
SOURCE: kyocera cs1820
c 7980 is a warning that the waste toner container on the imaging unit is full, This usually means the life of the imaging unit is finished or close to being finished. If u dont want to replace it yet, a quick way is just to empty it. on the left and right of the unit at the back you will see 2 screws take those out then remove the small covers and just poor the toner out(DONT BLOW INTO THE UNIT). put tje covers back on, clear off any spilt toner and put the unit back into the machine
SOURCE: scanner password
HI there try the following.
Hope this helps you
Thanks J
SOURCE: How to connect a Kyocera CS1820 as a network
Hook up a cat 5 cable from a network switch and load the driver on each workstation
