1. Try to set back a recent but older Recovery Point from the System Recovery. 2. If it does not help, set back an older Recovery Point from the System Recovery. 3. If that does not help, Restore a System Back-up (I hope you made a back-up).
why is it my yahoo messenger that id download now is failed to initialize properly?
can you please help me the right thing to do to make my download completed?
download revo uninstaller free from the website.
uninstall yahoo messenger .
download a fresh copy of the messenger from the website
install it
it will work
The failed install has messed Windows itself its integrated installer has been corrupted.
The easiest way to fix that is to reinstall, otherwise you will gonna have to manually delete all partially installed drivers, clean the registry and perform a Repair install.
Best is not to partition your Hard Drive to more then 4 partitions. If you are going to install more than 2 Operating Systems(OS) on your hard drive,be sure to set your partition to "active" for the intended OS before formating. If you set to more to 4 partition, most probably your OS will not be able to read the partitions and that are the reasons you are getting the errors.
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
Hi this is Vinay I also sometime have faced the same problem, i generally delete the game and install it over again. then it works properly and functions correctly
