Question about Tasco Astronomical 302675 Telescope
How can i make it....i want the measurements of lens to make it?
  • 3,186 Answers
You want to GRIND a lens? This is VERY difficult, and not worth doing for a Tasco telescope.
Posted on Jun 01, 2010
6ya staff
SOURCE:
Lg front load washer error le thermal overload circuit in mmotor
If the error code is "LE" then replace the hall/position sensor on the motor, if the error code is "tE" which looks a lot like LE at a causal glance then replace the thermistor that measures the water temp located on the bottom of the outer drum in front.
Aug 12, 2018 | LG Washing Machines
The green lights fuse has blown on my Le Chef kettle (keeps want to hot for 24 hours). How can I repair it or where can I take it for repair? Thanks? Dennis
If its a leaking gasket if the heating element is having short circuit or have a measure with the metal exterior is very rare must be only a melting wire, or a bad switch there is also a temp fuse between the element and the power cord.
Aug 08, 2016 | Le Chef Kitchen Appliances - Others
My Nikon d5200 won't focus and when I try get it too it makes a horrible squeaking noise?
Ri: It is almost certainly not a problem with the camera, most likely with the lens. Before you can look for a solution you must figure out what is causing the problem. If you only own the (1) lens you need to get access to another fairly new Nikon camera body & lens (whether from friends or just take your camera and lens to a local camera store)!!!!
If you go to a store, don't initially waste your time to try to explain the problem to the counter staff. Ask to see another Nikon camera and lens..., then when this is provided, put their lens on your body..., if it works properly with out squealing this is great news (it's the lens not the camera)...., but make sure, just in case!!!! Put your lens on their body..., if it squeals and doesn't work properly you have now positively identified where the problem is located!!
NOTE: IN MOST CASES IT IS THE LENS, ESPECIALLY WHEN THE LENS IS THE 'KIT' LENS!!!
If it is determined that the problem is the lens, how should you deal with it? First off..., is the camera and lens still inside the warranty period? If it is still inside the time frame..., you need to determine if the problem will covered by warranty. This is essential..., (the 18-55mm lens is not an overly expensive lens) as if you decide to send the lens off for warranty service and it is determined by the service station that the problem was 'user error' you will be stuck with shipping costs to and from supplier plus any parts and labour costs..., and if you say no to the repair you still are on the hook for an estimate fee!!!! (sorry for the doom & gloom)!!
Avoid all this hassle..., in most cases this issue is caused by misalignment in the lens...., easy way to determine if this is the case!!! Place the lens (front element down) onto a smooth flat surface (remove caps, hoods & filters), then take a accurate ruler and measure from surface to the back of the lens mount!!! Take this measurement at several points around the lenses circumference. If all measurements are the same it's an internal problem and most likely covered by warranty. If you are getting different measurements..., then you will be told the lens has received an impact, don't waste your time or money trying to get it fixed..., you can buy one of these lenses used for $50.00 to 75.00 CDN. Cheaper that what the repair and shipping cost will be!!
Hope this helps
Peter
Oct 26, 2013 | Nikon D5200 DSLR 18-55mm Lens Kit with...
Error Bosch DLR130 distance measurer
Same problem Err and --- on display. The front lens had become misaligned. Take off front rubber boot, clean lens and replace lens exactly in glue pattern on unit with rounded side facing out. Then holding unit with seated lens upright push rubber boot slowly back on. Very hard at first but push as much in by hand then use a narrow blunt point like the back of a screwdriver handle to press around the edge working it in with slow continuous pressure a quarter inch at a time. It will reseat just take your time and work the high spots. This time was not the batteries, works like new.
May 23, 2013 | Measuring Tools & Sensors
How can I measure a sunglasses frame?
A frame has 4 basic frame sizes.1. Eye Size - refers to the horizontal width in millimeters of one of the frame's lenses.
2.Bridge Size - measurement is the distance in millimeters between the two lenses. It is measured between the two closest points of the two lenses.
3.Temple Size - is measured along the length of the temple, from one end to the other, including the bend.
4.Vertical Size (B) - refers to the vertical height of an eyeglasses lens, and is measured from the tip to the bottom of the lens aperture of the frame. The measurements are taken from a horizontal line intersecting with the top of the lens, to the horizontal line intersecting with the bottom edge of the lens. The B measurement is only important when ordering multifocal lenses; follow this link to read more about progressive lenses.
Nov 07, 2010 | Clothing Accessories
Só le cd audio naum le dvd msg bad disc
Hi its look that you need to clean the laser lens
manualy open the cover press eject unplug the dvd leave the door open and with a qtips and alcool wipe gently the lens
and its done put the cover back and try it its should works
and make shure that you have a clean disk before try to play it
hope that will help you
regards Alan.
Oct 13, 2010 | Philips DVP3040 DVD Player
Mon nokia ne s'allume plus,et je ne sais pas comment l'ouvrir,pour si la carte est bien inserrée.le plus drole s'est que la prise de photos doit fonctionner car on entent le...
bonjours ; j ai nokia c2 BRUSQUEMENT IL NE SALLUME PAS . ARRET TOTAL . ETEINT . UN TECHNICIEN A VERIFIER LE BATTERIE ET LES COMPOSANTS DU GSM . INTACT . IL M A DIT QUE C LE SOFT . C VRAI ? COMMENT FAIRE ?
Sep 17, 2010 | Contax Normal 45mm f/2.8 Carl Zeiss Tessar...
Pentax optio e60 lens error 0x04110000
je viens de resoudre le probleme sur mon pentax E70L avec un simple aspirateur domestique,a l'aide du tuyau le plus fin, en realisant un nettoyage minutieux, tout autour de l'objectif, (sans rien demonter, evidemment!), ensuite le code lens error a changé, puis j'ai continuer a ouvrir et fermer l'appareil, a tenter de changer les options "scene", et l'appareil ne s'est pas refermer !...et j'ai pu refaire des photos!...soulagé!...l'appareil n'avait pas 2 mois!..mais rappelons nous qu'il n'aime pas le sable!
Mar 17, 2009 | Pentax Optio E60 Digital Camera
Tasco Astronomical 302675 Telescope Logo
Top Tasco Optics Experts
Ekse
Marvin
Marvin
Geoff
Are you a Tasco Optic Expert? Answer questions, earn points and help others
