Turbo C/C++
64 Bit operating systems like Windows Xp64, Windows Vista64, and Window
7 will no longer run 16 bit applications and this includes Turbo C
2.01/Turbo C++ 3.0/3.1 or the programs they produce.
Turbo C 2.0 was first released in 1989, Turbo C++ 3.1 in 1991 making
these programs nearly two decades old. They are just too old to run on
modern PCs.
Upgrade To Modern Compiler
Note that Turbo C/C++ is very very very very old and produces 16 bit
programs which no long run on many modern computers. So the best advice
is to upgrade to a new compiler. There are many free compilers out there that you can use.
Free Compilers:
If you are just working with C there is:
All of the above are Free and all excellent replacements for Turbo C which is so old it will not even run on your computer.
Regards.
You can use TurboC Patcher , this application lets you install , run or fix any existing TC installation , on you Windows Vista or 7 (x64 or x86 ) :
you can download it from here:
http://ustmb.ir/Projects/TurboC_Fixer_Installer.exe
there is yet another new product which will help these people :
Turbo C Simulator , simulates turbo c on your windows vista and 7 . http://www.softpedia.com/get/Programming...
SOURCE: how to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
SOURCE: how to run turbo c++ in windows 7 64-bit os
Is the program not installing at all? Or it just won't run?
Try using the compatibility options for it. If the program did in act install, open up the start menu, and right click on the application. Select properties. There is a compatibility tab. On that tab you can select the Checkbox to run the program in compatibility mode - WindowsXP SP2 usually works for most legacy apps.
