Red light blinking. Can not turn it on.
Thanks
The unit is trying to start and can not. It then enters protect mode.
This means that there is a problem and a full turn on would further
damage the set. It should be blinking a code, this code will tell you what the exact problem is. If you call Philips at 1-888-PHILIPS, they can tell you what is the exact problem.
To figure out the code, count the number of blinks.
If you need further help, please ask, but I can't tell you what to exactly replace without more information.
Thank you and have a good day.
Please don't forget to rate this solution
SOURCE: philips hdtv lcd 5 blinking red lights
If u want to see what model the tv is without taking it off the wall enter this code with your remote. "123654" on the first screen it will have your model number and serial number.
As for the error 6 its a 5volt supply error.
And for error 5 you have a bad osc crystal.
SOURCE: Philips 42PF5321D/37 LCD/Plasma HDTV puchased
Is it LCD or plasma? There are two different versions of this tv and the troubleshooting guide for both are different. So please confirm this. You can find it on the label behind the tv.
