I have an old sears deep chest freezer. I defrosted it and removed the plug to drain the water, but the water isn't coming out. Is there another step to draining it?
Don't hit or punch the freezer walls ,just unplugged and let the frost melts and this water will go through the drain down to an evaporative pan.Make sure the drain is not clogh if it is clogh put hot water into it or blow it with air pressure.
is this a chest freezer? Thick frost around top? try defrosting unit. DO NOT scrape the ice. Very important to remove drain plug to remove water or frost will very rapidly redeposit
The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor.
A new defrost timer should be available from the local refrigeration wholesalers in your area.
There are numerous methods to defrost freezers, from placing buckets of hot water inside to using hair blowers. I like to unplug freezer, unload freezer, use a plastic putty knife to scrape excess frost off walls if in a bit of a hurry, and to let it just thaw out, using the drain port in the bottom of the freezer, hooked up to the garden hose adapter that came with the freezer to run the water to a drain.
The chest freezers are a bit more reliable than an upright (in my opinion) and are more energy efficient, but do make it harder to find and organize items in the freezer. FYI: Virtually any brand name freezer on the market in the US was built by either Frigidaire in St. Cloud, MN, W.C. Woods Co., from Canada, or Haier Co. in China.
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
