I for 1 don't know. But try to go to www.Turtle Beach.com they can help you out. I have Turtle Beach Ear Force XC1 and my mic I can talk but I can't hear anything but if your mic isn't working properly try using a different controller. If that doesn't help try getting a brand new mic.
If you have an X1 headset...
Try using the X1 headset and mic with your PC (sound card). Green plug goes to green jack, Pink plug goes to pink jack. Can you hear your voice thru the X1 mic on your PC? If yes, then the mic works but the chat-controller cable is probably broken and should be replaced. If no, then the mic may be broken and you should contact Turtle Beach's tech support for help -- [email protected].
Try the X1 on your PC or laptop to check if it's working OK. if you can hear fine on the PC, then there's nothing wrong with the headset and you should check the XBOX connections or RCA splitter cable.
That sounds like the chat/controller cable might be to loose in the headset jack. Turtle Beach has a newer cable available that should fit tighter. Their email is [email protected].
Have you tried using your X1 on your PC? Try connecting your X1 to a PC and speak into the X1 mic. Can you hear yourself in the headset? If yes, then the X1 mic and headset are OK but you need a new chat-controller cable. If not, then you should contact Turtle Beach about it --- [email protected].
Try using your X1 with your computer. Plug the X1 green plug into the green jack on the PC. Plug the X1 pink plug into the pink jack on your PC. Try using the headset to listen to the sound of your voice. Can you hear your voice through the headset? If yes, then the mic is OK but the chat-controller cable needs to be replaced. If not, then you should contact Turtle Beach tech support at [email protected].
