Question about Intex Easy Set Pool 15x36
The top ring on my easy set pool leaks air. How
The top ring on my easy set pool leaks air. I can't find a hole .How can I fix it?
  • Anonymous May 25, 2010
    I already tried that and it did not work, but thanks!
  • dennis May 20, 2013
    most likely the air filler nipple, fatal, throw the pool away. one might try inflating the pool ring, then dry off the air filler nipple, push on the cap, then invert the nipple, then apply GORILLA BRAND duct tape over the inverted nipple., ONLYGorilla brand tape seems to work.
  • 843 Answers
I suppose the pool is already full of water. You could remove some of the water, then use soapy water and a paint brush to find the leak. Bubble blowing liquid is ideal for this. This will be easier on the the outside than on the inside. Once found, you may be able to fix with duct tape. But they sell repair kits that probably work better. Don't use a tire or bike tube patch - those are for rubber. I hope this helps you, and I hope the kids have fun in the pool this summer! Al K
Posted on May 25, 2010
6ya staff
SOURCE:
Ring doesnt keep air
Put some Ivory dish soap, about a tablespoon, in a quart bottle with a sprayer, and fill the ring with air.
Then start spraying the soap solution all over that ring. When you see "Bubbles" appearing, that is where the leak is. Patch it. Fill with air & repeat. If no more bubbles, you have fixed it.
Apr 06, 2014 | Intex Easy Set Pool 15x36
Air leak ring
patch with pool patch
Aug 11, 2013 | Intex 10' x 30" Easy Set Pool
WANT A SOLUTION AS TO THE RIM I HAVE TO PUMP UP TWICE A DAY WHAT DO I DO ????????
There will be a hole in a seam most likely. Take some soapy water and go around the seam on the top rim where it goes together and locate your leak.
If the top won't stay full of air there is definitely a leak.
Rod
US Parts Center
888-521-6183
Mar 04, 2013 | Intex 2500 Gal Easy Set Swimming Pool...
Air ring leaking on 18 foot pool....cant find leak...if it is the seam how do i fix it???
To be honest, ive seen 20-30 customers come to my company looking to fix this same problem. Weve tried vinyl patch after vinyl patch, and several different cement fixes. Nothing works.
The best results ive had are with a simple vinyl liner repair kit.
The most important thing is to let it sit for 48 hours before reinflating, but even this fix was only temporary.
Long story short, you get what you pay for, and intex is the cheapest pool systems on the market for a reason. The air ring always starts to leak right after the warranties are up, and the Intex company just plain out doesnt care.
Wish I had better news.
Mar 29, 2011 | Intex Easy Set Pool 15x36
I noticed my pool was leaking air. I opened the upper ring blow up valve and there is hole inside of it. Can this be repaired? I would hate to get rid of my pool just because the air valve has a hole...
Take a 12 X 12 piece of plastic wrap, wet the pool ring, slide the plastic sheet along until you see the air bubble appear, mark leak with marker pen. Use repair patch. I swear this is better than soapy water!
Jun 19, 2010 | Intex Easy Set Pool 15x36
Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
May 20, 2010 | Intex Easy Set Pool 15x36
My model 603 filter pump leaks at the top under cap
It could be the o-ring on this model. There is a seal on these pool filters that looks like a rubber ring inside the lid. You might need to replace this ring if your pump is leaking here.
Apr 30, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
All o-ring attachments to filter leak
My neighbor had this trouble also she was trying to put the o ring in the grove of the top it does not go there it just sits on the unit and the top screws down
Dec 08, 2008 | Intex 2500 Gal Easy Set Swimming Pool...
Intex Easy Set Pool 15x36 Logo
2,556 people viewed this question
Top Intex Pool & Spa Experts
Mike
US Parts Center
US Parts Center
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
