During spin cycle some water accumulates on floor from the outer wall of drum.
SEAL IS MOST LIKELY LEAKING BETWEEN AGITATOR AND DRUM, SEALS ARE CHEAP AND DEDERGENTS OVER TIME CAN WEAR THEM OUT.
Testimonial: "Thanks SKEETERJES! Have just received your suggestion but certainly sounds right! Many thanks!"
may have something stuck in diverter valve tip washer on left side look under rite side find valve with 3 hoses one hose goes up sameside of tube unplug power from outlet remove the 3 hoses from the valve un plug the two wires remove 1 screw you now have the valve in hand look in valve see if somthinextra is in their ! that fixed mine i had a wire tie stuck in it
I had the same thing, water would come out over the sides in the final spin. I pulled the diverter valve and found 2 safety pins and a bobby pin. Works fine now.
