The motorola A1000 does have a signal problem, however a signal booster has been released and can be purchased by following this link: http://www.mobilephonecrazy.com/modeldetail/a1000,Signal_booster.htm
You can get your network unlock key from your service provider or else try to buy from any one of the online unlocking service provider like MobileUnlockSolutions.com Here you can unlock your Motorola A1000 phone at low cost.Once unlock your phone,you will be able to use in SRILANKA without having any problem.
buenas amigo lo que tienes que hacer es irte a la lista de contactos, coges el numero que esta en el cel, lo celeccionas vez que arriva dice edit, al lado de contacto, y vas a la opcion copi contac to USIN y listo te pasa el contacto a la sim card, esto tienes que hacerlo contacto por contacto...
did you use of 3g, or just you frequency is changed. with motorola you can select regime manualy and frequency too. try in phone settings to set frequency to auto and 3g too.
k, having an a1000 i have had similiar problems except in my case could not recognise a memory card the same as the 1 i alrdy had in it, i also had a problem witgh the slot for the memory card, which in ur case cud be that simple that u have overlooked it, my suggestion is to try different sims in it and see if a network works, if none do try getting ur card and making sure its stuck into the slot, im sorry this isnt much help but cud possibly be a pcb error or may have a problem with the receptor.
ok, well as far as i remember gps doesnt come standard with the a1000, it has an agps socket which means gps capabilities for programs like tom tom. But the only thing i can tell u is to turn on ur agps socket before using the program, otherwise your gps program may have been deleted, thats all i can say as if u do(or did) have a gps program on there it should show up in applications icon.
Here in the UK most markets (out door street type) will have a stall who will unlock most handsets for about 5gbp (or 10usd) you could also ask three themselves to give you the unlock code, they do so here in the UK and europe. Tell them you are to travel abroad and wish to use a local sim card to make calls. Also do a google search for "A1K" and go to the site at top of list "machman" they have downloads of firmware which is unlocked.
What network? Usually a call to the network operator or a visit to their website will provide a method whereby the network can push the settings to your phone via the network.
Is the IDEA sim card a 3G USIM or a 2/2.5G SIM? The A1000 is a 3G phone, and the SIM card is not the same as a 2/2.5G SIM, so compatibility is not guaranteed and may be the cause of your reboots.
