I have an issue with HDD and have upgraded it to 500 gb drive and used recovery DVD etc to restore to factory settings. I have now on reboot tried to used f8 to access system restore but under advanced reboot options system restore is not available. I have a full PC backup that I want to restore from. How do I get around my problem?
SOURCE: black screen asus pc 900
Not thinking it is the bios, as if that were bad, the computer would not work. It is possible that the program (or programs) you are trying to open are not linux compatable. If that is the case, you will have to re-load a compatable operating system.
SOURCE: blue screen arrives ...system not working
At bootup press F9 to restore to factory condition
SOURCE: i want to recover my
You have to disable "boot booster" in the BIOS first....then as soon as you turn on the power start to press the F9 key about every second.. and click the check mark to start system recovery
SOURCE: Help with reboot message for Asus G1 notebook.
Sounds like its trying to boot from the Optical drive (cd/dvd drive) thats empty or has no disc in it. You will need to get into the BIOS and change the boot sequence. Select HDDR 1st to boot from your C: drive where your OS is.
SOURCE: how can i restore my asus laptop to factory
On srartup Keep hitting F9 until restore screen pops up.Follow instructions (Your Choice Of Partions).2 partitions puts it back to factory, and you can start off like new.
Before going any further, please help to confirm the following three points:
1. Does any other error message appear when starting the computer?
2. Did the computer start properly before?
3. Have any changes been made on the computer recently, such as an installation or upgrade?
The issue can be caused by many factors, such as incorrect BCD entries and incompatible hardware or software.
Based on the current situation, I suggest trying the following methods to troubleshoot the issue.
Method 1: Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ..." appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Can the computer be started now?
If the issue persists, I would like to confirm if System Restore was enabled before.
If so, we can try to restore the system to a state when your computer worked properly in WinRE.
Method 2: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Instert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
