Hi, i have connected the cable line directly to the t.v into ant-a but i am only receiving 12 channels, i have tried to add more channels to the memory but it does not work, should i turn off ant-a ? or ?
Hi ismael
To answer your question;
Connecting to ant.A will do fine.
Go into your menu and look at "ant.A" if it is written"air" you`ll have to switch it to "cable" and then memorize/scan for channels.
If you`d like the owners manual just click HERE
Hope this help and good luck
1 Find and disconnect the cable that is connected to the
ANT IN terminal on your cable box.
? This terminal might be labeled "ANT IN", "VHF IN" or
simply, "IN".
2 Connect this cable to a two-way splitter.
3 Connect an Antenna cable between an OUT terminal on
the splitter and the IN terminal on the cable box.
4 Connect an Antenna cable between the ANT OUT terminal
on the cable box and the B-IN terminal on the RF(A/B)
switch.
5 Connect another cable between the other OUT terminal on
the splitter and the A-IN terminal on the RF (A/B) switch.
6 Connect the last Antenna cable between the OUT terminal
on the RF (A/B) switch and the ANT IN (AIR/CABLE)
terminal on the back of the TV.
After you have made this connection, set the A/B switch to the
"A" position for normal viewing. Set the A/B switch to the "B"
position to view scrambled channels. (When you set the A/B
switch to "B", you will need to tune your TV to the cable box's
output channel, which is usually channel 3 or 4.)
OK
