SOURCE: Printing envelopes
You will probably have to change your paper settings on the printer itself to proceed without an error. In the additional settings>Paper Size> change it from Ltr to Envelope.
SOURCE: How do you print envelopes on the Canon Pixma iP460
I print envelopes a lot for my business.
What I do is I use the regular paper feed, and I open the flap on the envelope so that it's flatter. Simply slide the paper guide to adjust to the size of the envelope.
Also, typically the orientation for printing envelopes is sideways. You put the left edge of the envelope in the printer first. If you are unsure of the orientation, simply do your first print on plain paper. Then you'll know how to insert the envelope.
SOURCE: Pixma iP2600 Photo Printer InkJet: Canon iP2600 error codes...
my printer will not print out anything. it starts to but the paper never enters into the printer, it is almost like it is jamed but it isn't.
The message says there is an error, push resume and try again.. same thing, it starts to push paper thru.. acts like a jam.. same message.. but paper is not jammed
