Normally there is a kodak software you run on the PC and it show you the pics from the camera. Your trying to print directly to the printer without a PC? If so then you would use the printer menu.
UPDATE: Found the 310 user manual online from the Kodak site.
Make sure it's an SD and not an SDHC card. Press the MENU button. Use up/down to highlight Setup (four horizontal sliders) and press the OK button. Use up/down to highlight "Format" and press OK.
You can view/download the manual at http://support.en.kodak.com/app/answers/detail/a_id/18621/kw/c310/selected/true
The C310 works with MMC and SD cards. MMC cards are nearly obsolete and hard to find, so I suggest SD cards. Be sure you get an SD card, 2GB and smaller. Larger cards are actually SDHC cards and will not work in the C310.
If you have an older Kodak digital camera, it probably won't format a new card unless it is under 4gb - I had to return my new 4 and 6 gb cards for a 2 gb. Now it works.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Hey hardygurl198, What is most likely going on is you need to format the card so it will work in your camera. Every time you get a new memory card for a digital camera or if you put a memory card formatted to a different camera in a new digital camera you will need to format the memory card before you can use it. Directions on how to format your memory card are on page 27 of your camera manual, and I have provided a link to a PDF download of your manual in case you need it. I hope this helps! http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00431/C310_CD40_GLB_en.pdf Sincerely, Allan Go Ahead. Use Us.
