The tv is 13 years old. After being on for about 10 minutes, double images appear. What is the problem and can it be repaired?
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
