Hitachi UltraVision 60V715 TV Logo
Posted on May 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need manual for hitachi ultravision 60 inch tv
Anonymous
Level 3:
  • Master 1,476 Answers
  • Posted on May 28, 2010
Anonymous
Master
Level 3:
Answers
1476
Questions
0
Helped
340149
Points
4062
For a free download of your manual try http://www.retrevo.com . They should have what you need. Let me know if you need more help.
Thanks for using FixYa and for the great rating.
hardrocko
The tv turns off randomly. sometimes i can't get it back on. 60 inch.
check your smps filter capacitor ,feedback line,starting plus resistance.
2answers
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
How heavy is a hitachi 52 inch dlp tv
The weight of the hitachi 52 inch TV is around 94.1 lbs 0r 42.6 Kg
Thanx
I have a 1999 hitachi ultravision 60" projection tv and the power will turn on but minutes later it shuts itself off. How do I correct this problem?
When was the last time the projection lamp was replaced?The projection lamp on the tv now,has not been replaced like a 1 1/2 or 2 years,tv been on and watches like 4 or 5 hours a day?The tv projection lamp life are over.Require a new projection lamp.
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
1helpful
Hitachi 60" Ultravision TV - bad green tube that is leaking
If this has only started to leak recently, get an estimate from a local servicer for a coolant replacement for that tube. The coolant is corrosive and needs to be cleanedup ASAP from any circuit board that it has touched before there is damage. This is NOT a DIY repair. Expect a repair cost in the $300 range for parts and labor. If the set had a good picture prior to this, it may be worth the repair. This is your call. Do not delay however, as any delay will increase the likelyhood that there will be more damage that needs repair.
Dan
7helpful
5answers
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
60.5 inch ultravision rear projection tv - circa 1999-2000
If you provide model number I can suggest correct remote control to buy.
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
1helpful
Hitachi 60 inch ultravision
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
