Question about Dishwashers
The unit is a Maytag model MDB5601AWW which it has recently began to lose power at the touch pad. The electrical breaker has been checked to confirm normal voltage. Additional investigation suggests that the unit can be reset by (1) disconnecting the power at the breaker, (2) disconnecting and reconnecting the ribbon cable that interfaces the touchpad with the control board. However, the problem reoccurs after a few normal wash cycles.
  • 159 Answers
It sounds to me then that the display board or touchpad needs replacing,you havn't said that it's not doing it's cycles.so it's not causing any washing or cycle problems.i would replace the display board.
Posted on Jun 04, 2010
6ya staff
SOURCE:
Maytag model mer6770awc keeps showing f1-1 error code
Hi rayrolls,
The F1 fault code indicates a defective touch pad or clock (ERC). To resolve this issue, you need to replace touch pad or clock (ERC).
The steps below will help you to determine whether the ERC or the touch pad is defective.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Sep 14, 2011 | Maytag Kitchen Ranges
Have a GE Monogram Oven Single Wall Unit. Began Flashing F1 last night. Model GL2788960. Its hard wired so I turned off breaker let it cool down and turned back on. Still Beeping.
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
Dec 18, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Model 5770ACW 19401490Z. An hour into self cleaning I heard a beep and a F1 appeared on the screen. Can you tell me what happened and what I need to do to fix the problem. Thank you
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
Sep 11, 2010 | Maytag MER5870 Electric Kitchen Range
What is an f1-2 error?
Sep 07, 2010 | Maytag MER6772 Gemini Electric Kitchen...
My oven keeps beeping and flashing an f-7.....what can i do to stop it?
Turn off house breaker to the unit at the breaker box of your home. This will be a double breaker.
F7 Touch pad or Control board...... Most techs start with touch pad.
Sep 05, 2010 | Maytag CWE5800A Electric Double Oven
It appears F1 at the beginning of the preheated one of the furnace
Hi pillis_2y4,
The F1 error code description is a defective touch pad or clock (ERC). Here are some steps that you may apply to check if the ERC (Electronic Range Control or Clock) or the touch pad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker. It is very important that the power to the range has been disconnected, so please double check before continuing.
7. Please replace the ERC, if F1 comes back. If it does not, replace the touch pad.
Hope it helps.
Jul 08, 2010 | Maytag MER5775Q Electric Kitchen Range
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
F1 on the read out comes up and the oven well knot work it keeps comeing up f1 on read out it is a maytag rang mer5770aab sel.no.13196174uu
Hi martysherrip,
The F1 fault code description is a defective touch pad or clock (ERC). Please refer to the steps below for additional information.
6. Wait for at least one hour to see if the F1 code comes back.
Hope it helps.
Jan 02, 2010 | Maytag MER5775Q Electric Kitchen Range
Maytag oven shuts off?
Hi. This is a possible touch pad, or EOC(Electronic Oven Control Board) failure code. The test below will help isolate the issue.
This simple test will help determine whether the EOC (Electronic Oven Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the EOC as a single assembly, in which case this test is not necessary. Simply replace the EOC (Clock).
Nov 20, 2009 | Maytag MEW5530D Electric Single Oven
Maytag oven reads fi
Defective touch pad or clock (ERC)
Jun 01, 2009 | Maytag Ovens
Dishwashers Logo
182 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
