We had this same problem recently. Don't know if your problem is the same, but I am sure it could be.
While we did have hot air coming from the outside vent, it was still a restricted vent duct that was our problem. I went to Lowes and bought a dryer vent cleaning kit for about $40 (I figured I needed to do this anyway, as I'd been hearing about how many housefires are caused by the heat buildup from poorly breathing vent tubes/ducts), and cleaned the whole length of the duct (and replaced the plastic flexi-tube inside with a metal one).
I had thought I had good air-flow before doing this, but oh my gosh, what a difference this made! And I couldn't believe the pile of nasty, damp lint that came out!!
Anyway, our dryer immediately went from requiring 2-3 cycles to dry a load of clothes, to doing a great job the first time through! Perhaps the same solution would help you. I hope so!
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
