Panasonic Lumix DMC-TZ1 Digital Camera Logo
Posted on May 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does not connect with computer for download - Panasonic Lumix DMC-TZ1 Digital Camera
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on May 31, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200596
Points
38521
Use a card reader instead of the camera.
Why does my pc crash when i download my photos from the camera
It could be the camera, the connection, the computer operating system, the program on the computer you're using to download, or any of half a dozen other reasons.
If you're most interested in getting your photos downloaded than in pinpointing the exact cause, consider NOT connecting your camera to your computer at all.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 04, 2012 • Cameras
Communicate with computer (PC).
Hi, in order to connect the Nokia 3230 to the Computer, please download and install the Nokia Ovi Suite in the Computer, then connect through USB Data Cable which can be purchased in any Nokia Showroom or Mobile Shop.
Download Nokia Ovi Suite from the below link:
http://europe.nokia.com/support/download-software/nokia-suites-for-your-pc
You can also connect the Nokia 3230 to Computer using Bluetooth feature if you purchase the USB Bluetooth Dongle for the computer.
May 03, 2011 • Nokia 3230
How do they connect to the camera
I presume your question is a typo. Cameras do not connect to cameras, they usually connect to computers to download the photos. The camera shouold have a download cable with a normal USB plug on one end that connects to the computer and a very small plug at the other end that connects into a matching socket somewhere on gthe camera. If you have the camera socket but no cable then either go buy a cable from any computer or camera shop, or you can remove the camera storage card and insert into a computer card reader. It will then act as a new drive and the computer will give it a drive letter. The same will apply if you use a connecting cable between camera and computer. Either way when the computer recognises the camera card, it will give it a drive letter and you can then download your pictures to any folder on your computer. However, almost all digital cameras have download software on the driver disc and if that is the case with your camera then go get the connecting cable - take the camera with you to the shop if you're not sure of the cable type
Dave
Mar 12, 2011 • Cameras
When i connect the cell through data cable it shows usb device not recognise??? why??
try downloading NOkia Connectivity Driver from Nokia's Website... Download and install it...Restart your computer and then connect your cellphone to the computer via Data Cable...
You can download Nokia Cable Connectivity Driver from here:
http://europe.nokia.com/support/download-software/cable-drivers/driver-for-nokia-dke-2-dku-2-ca-42-ca-53-ca-70-ca-101
I have problems downloading the pictures. I have Windows Vista on my computer and I downloaded the drivers, but when I connect the camera by way of a USB port (2.0), Windows Explorer doesn't show the...
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Won't download to computer. "Cannot read Device"
Initializing USB connection is on lcd screen, computer does not recogize device. If I hold the connection from cable to computer I can sometimes get the "download images", then try to download...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Won't download pics "Establishing Connection"
Internet shut down.
Try changing your power settings to Always On when downloading overnight. If the machine enters sleep or hibernate mode, it will drop any active downloads.
3answers
My mp3 won't connect
that happened to me your computer might have a viris go to a friends or someone elses house and try it one there computer
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
