Hi AC9746
The 1st thing to do is connect an external monitor to your computer. Connecting an external monitor to it will very quickly point us in the direction we need to go in troubleshooting the issue.
You may need to close the "lid" of the computer in order for the display to show up on the external monitor. Hopefully this will work since you're unable to see the display properties in order to select the external monitor.
If the display works w/ an external (**known good**) monitor connected to it then the issue is w/ the laptop's monitor. The next course of action is most likely to contact HP for warranty repair (if your computer is in warranty) or to replace the monitor.
If the display still doesn't work w/ a **known working** external monitor connected to it, then the issue is w/ the onboard video.
You can find manuals for your laptop HERE. However, I don't see a service manual there.
You can find HPs "Solving Problems" for "Display, Video and Graphics" HERE.
Resolving Problems w/ the Brightness of the Display
About LCD Panel Defects and Terminology
Display is Dim During or After Startup - Windows XP
Display is Dim During or After Startup - Windows Vista
Please, let me know if this response was a "FixYa" (enabled you to successully diagnose your problem) or "Helpful" for you or, of course, if you have additional questions, etc on this topic.
If the solution I provided you w/ resolved or enabled you to diagnose your problem or answered your question, a "FixYa" would be most appreciated. :)
It is best to wait until the problem has been resolved b4 scoring the experts who participated in solving your problem or answering your question.
Very often it will take more than one exchange of information between you and an expert in order to resolve your problem.
If a proposed solution doesn't work for you, please, don't rate it yet. Instead, post back here letting us know and we'll continue to work w/ you until we find a solution or we're able to diagnose the problem for you.
Thank you
BJ
The parts listing for your computer can be found HERE, however, I don't see the monitor listed there for either of the models.
You can contact HP using the information found HERE.
You will need to provide them w/ the particular model no. you are referring to.
Pavilion DV622US [RP297UA] or [RP297UAR]
Hello AC9746
How did it go? Did the information and links I provided you w/ enable you to determine if your LCD monitor needed warranty repair or replacement?
I DO hope that is the case. :) If it isn't, please, post back here and we'll continue to work w/ you.
If it is the case, would you kindly take just a moment to close the problem by assigning a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
Thank you once again for using FixYa! Have a beautiful day.
BJ @:)
The VGA card or the VGA driver is not properly installed,perhaps.Try reinstalling the driver.
If you suspect the monitor brightness controls then try fiddling with them untill the brightness is good enough.
Check monitor cable also(VGA).
my monitior screen shows lines up & down. in other words the screen blinks continous . my monitior is in warrantry period. so kindly do the needful as soon as possible.
