You also need to pay attention to the disc damage issue. To some degree, the issue of computer DVD player not working is simply related to the disc only, check whether your disc is damaged, for example. Discs are prone to damages such as scratches, dirt, and so on. Before inserting your discs to the computer, make sure that the disc is not damaged. The last thing we want to see is the disc has been damaged. However, if that least-expected scenario happens, you may try some simple methods to recover the disc.
You can check for solutions in the source article.
Source: Why Does My DVD Player Not Work on My Computer
Some dvd players (outdated)..will not play these new dvd (recorded or pre-recorded dvd)...if you are recording dvd and wish to play on another dvd player (dvd player must be at least 2009)...same thing happen with my toshiba recorder...my jvc player works its (2008), but my sony dvd (2004) did not play any of the recorded dvds (only the store brought).....suggestion buy a not expensive dvd player (you just need it to play all that other features will push the price range up)
hope this help
SOURCE: philips dvd player 616k
have you tried to record in sp then playback on same machine if this works then your drum for recording in lp or if yours has ep mode may need replacing as pre recordings are ok you need to get it serviced. hope this goes well
SOURCE: Daewoo DVRS05 Recorded DVD won't play in OTHER DVD players
my suggestion from reading other forums is that these players sometimes have problems finalizing the disc.. you could try making a copy of the disc in a computer to see if this fixes the promlem or maybe media these use dvd+r and has a lot of compatibility issues with dvd players.
SOURCE: rca dvd/vcr dual recorder, wont play dvd
My VCR/DVD Model # DRC6200N is not working. I can hear the DVD but no picture, do you have any suggestion what is wrong?
SOURCE: recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
