Troubleshoot: Some of this might be pretty obvious.. but it doesn't hurt to check them. Have bucket and some rags or towels available to catch water during the troubleshooting and test. Unplug any electrical connections
1) check to be sure the valve to the cold water hose is open.
reconnect and test, if not re solved.
2) shut off the cold water valve and remove the hose to check that it is clear and 1) water flows through the valve and 2) that the hose works (ideally on another faucet connection.)
With the hose still removed, check to see if the connection point at the washer is clear & clean.
3) reconnect working hose to working faucet and to the clean & clear washer connection. plug it back in and turn the cold water valve back on and and retest.
If its not one of these external connection issuess, call a repairman.
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/steven_7f54ab9063554f66
